Always On Booster
  • bbill335bbill335 Frets: 1391
    SHO at the end of the chain, seems to bring out the best in both the pedals before it and the amp after it
  • LebarqueLebarque Frets: 3940
    edited April 2018
    Branshen said:
    If a booster is always on, is it still considered boosting?
    Yes, because it's boosting the signal which hits the front end of your amp.
  • 57Deluxe57Deluxe Frets: 7349
    edited April 2018
    I run my LP DC Jr with a KoKKo Booster into the mixed drive of my Session Rockette 30 to get the most enormous erection delivering tones available to Man.
    You don't need to spend mega £$ to get a tone-on.
    <Vintage BOSS Upgrades>
  • JohnPerryJohnPerry Frets: 1625
    edited April 2018
    I had an RC Booster on full-time for years. Then I turned it off and turned the amps up and was happier for it.
    I found the EP Booster just added mud.
    The Diamond Comp is a good shout, makes every pedal after it sound better.
    But the real revelation is the Simble Pre-driver which beats the lot for me, a magic combination of extra beef, sparkle and smidge of compression. Heavenly into a Princeton
  • Flanging_FredFlanging_Fred Frets: 3114
    edited April 2018
    This thread reminds me that I really should get my old Dod Bifet pre-amp out of its box and play around with it again.  That's ones always on because it doesn't even have a footswitches on it.
    I have one of these, it's a great pedal when it's on - the bypass tone sounds a bit cloudy though.
    Not so much of a problem when you CAN'T turn it off
  • TheMarlinTheMarlin Frets: 8074
    Nocturne Atomic Brain
    or
    Simble Pre Driver (awesome)
    or
    Durham Sex Drive.
    Current setup is Simble Pre Driver after tuner, and Durham Sex Drive after OD’s.  Both ALWAYS on.
  • I've recently borrowed and OD3 from my mate and I can't turn it off. I'm doing that Andy Timmons thing of getting my clean tone from an OD pedal and I'm very happy with it. I'm just back from playing a wedding and my strat running through the OD3 with the guitar volume set as needed per song, then kicking in a TC Dark Matter for big solos, is the best sound I've had in a long time.
    "As with all things, some days you're the dinosaur, some days you're the monkey." Sporky
    I play my Cornford Roadhouse with its in-built Boost always on!
