Amp nerds...what wrong with this?
spark240spark240 Frets: 2089
Got this TE combo with no speakers in it, tried with a external cab seems fine, stuck in 2 speakers known to work and get this weird high pitch noise , you can hear it as I turn up the volume, its a bit like interference, but the fact that an external cab is fine suggest its a speaker issue ?
No input connected at this point
https://www.flickr.com/gp/149260669@N02/0G611o
Mac Mini M1
Presonus Studio One V5
 https://twitter.com/spark240
Reddit r/newmusicreview
  • ICBMICBM Frets: 72558
    Very odd. I don't know what's causing that, or why it doesn't do it through the external cab. The only thing I can think of is that the external speakers don't have enough top-end response to hear it.
    But - those speakers don't look like they're high enough rated for the amp anyway. What are they? They look like old Celestions...
  • mr-macmr-mac Frets: 200
    I assume the Ohm of drivers and way they are wired up are presenting same load amp is expecting.
  • Danny1969Danny1969 Frets: 10453
    It's possible there's oscillation getting through to the power amp either from one of the opamps in the pre amp or the power amp it's self. open Snubber cap \  circuit not functioning maybe ?  and your hearing lower harmonics of that oscillation but they aren't noticeable in the external cab due to lower frequency response
  • spark240spark240 Frets: 2089
    The speakers are Goodmans 12p Audiom Power range
    Fundamental resonance 85Hz
    Nominal power handling 50 watts
    1" 3/4 voice coil
    Efficiency 96dB @ 1 metre 1. 6 W
    Yes probably underrated wattage, would that cause that sound?
    Mac Mini M1
    1" 3/4 voice coil
    No, but you will very likely blow them. Goodmans speakers are notoriously under-rated for power handling, I wouldn't even run those with a 50W amp for *both* of them if you can avoid it. They're more like a 20-25W speaker in reality.
    edited April 2018
    Mm...I have some celestion V30 16Ohm...maybe try those?
    Mac Mini M1
    I would fix the amp first otherwise you could blow some nice speakers regardless of the volume you set.
