It’s the only one that doesn’t have that over-compressed EL84 sound, for the simple reason that it doesn’t use EL84s .
The guitarist in my band uses one, with humbuckers and fuzz and boost pedals, through a Marshall 2061 2x12”... it sounds great.
I’ve never seen a single faulty one, for anything other than a blown power valve.
Should be perfect for your style of music, although you may find it tricky to boost if you're pushing the pre-amp gain hard (an EQ pedal is the common solution to this issue). More so if you're having to constrain the power amp.
It's a great sound, and a great build - shame they don't still build them.
