I shouldn't really start a new build thread, as i have loads of stuff to do - but this is something i have been promising my cousin for a few years.
its going to be a through neck, vaguely Caparison inspired 6 string with fanned frets.. i have not designed it yet, but started on the wood prep
he has asked me to use a piece of old mahogany from his mothers fireplace - its been the mantle in an old farmhouse for a long time. Its nicely dry, very light and has a great tap tone. He won;t let me build a les paul out of it, so its getting used for the wings on this
neck is 5-piece
with some nice flame
and he has stolen a fretboard i was going to use on a headless for me, but that's okay
*Never thought I'd say that to a chap!
nice amount of flame in it
made a template for the body and roughly cut the wings to shape
and cleaned the top up a bit
My cousin is a big fan of the Caparison shape and headstock so since this is a non-profit build for a family member i may go with it, The shape is slightly tweaked and downsized a bit, halfway between an N4 or dinky and full strat dimensions
Instagram
but its its the kind of wood I like. A lot more interesting
Instagram
Then i went to cut the neck blank out and it became apparent my 25+ year old little bandsaw wasn't going to cut it. I struggled to get decent blades for it last time i looked a few years back, but found Tuffsaws had some this time around.
I was thinking of scrapping the old thing, but the new blades and a good clean and service have worked wonders
you can see where i gave up with the old blades and started with the new
its one of these little things - apparently still capable of cutting through 4" laminated maple with the right blade. It was second hand and quite worn when i got it. its cut out every guitar i have ever made except the very first one. i am sure it will keep going a bit longer
Instagram
I got the bi metal ones i think
(formerly customkits)
top is joined and is currently being laminated with a wenge backing. Fretboard has been cut out and also laminated to some wenge, that is currently being stuck to the neck shaft.
i am liking the top. Its been a while since i did anything with quilt. This was a bit of a reject piece because the consistent figure is at the narrow end.
Instagram
Instagram
it will get wiped down with water prior to finish sanding. It will get wiped with thinners prior to spraying.
Instagram
Given the maple/maple neck/fretboard combo i added a wenge accent line under the fretboard
and teh top has been roughly cut out to slot over the fretboard. don;t want to trim it too much at this stage.
we have agreed the top will be a trans black burst.. the rest will be natural
Instagram
Instagram
this is the inspiration (it won't be a copy, there isn't room for that level of detail), so i need to practice my engraving. ....
If that doesn't work, i have a backup plan
Instagram
then i did some practice runs at some straight lines and curves with a new graver from smallwonder. The straight lines were not quite deep enough, and the curves are not quite smooth enough... but i think its a promising start and i am getting used to the graver
Instagram
Instagram
