Removed most of the bleed on the drums using a fast attack multipressor, Snare gets a big plate on a bus.
kick and overheads have parallel compression.
Bass, just a bit of compression and EQ.
Lead guitar - EQ, send to bus with the plate and I have cut out all the dead space from the track.
Rhythm guitar - EQ send to bus with the plate.
Vocals - Cut out everything except the vocal from this track. Mild compression, small amount of pitch correction and send to bus with plate reverb
Master track has light compression, EQ and limiter.
Tempo raised slightly to get it jogging along nicely...
Happy to be told to piss off if not
Bandcamp
Spotify, Apple et al
Definitely ended up too quiet though.
Did the same for the bleed on the 5e3 track
my mix was done by just basic panning, levels, compression and eq. Add in a little reverb here and there and it’s done.
You want each element to sit in its own space on the stereo spectrum, if everything is set up the middle, each track will stamp over the next and it will sound muddy for example.
in addition to the panning you have to consider EQ on each track for the same reason. The pic below will give you a rough idea of where stuff resides on the frequency spectrum.
There are other tricks you can use. The drum overheads have picked up pretty much everything in the room. I wanted just the high end of the drums (cymbals essential) so I used a channel eq and cut all of the frequencies below 800hz or so, this leaves just a "sizzle" to the overheads, each OH track has been duplicated and the second is heavily compressed and mixed in just a little to add a bit of body (parallel compression).
parallel compression was used on the kick to give it a bit of oomph.
I try to get the panning sorted, then levels, then EQ etc...
Just to add, Im very much a beginner at this as well!.
https://twitter.com/spark240
Reddit r/newmusicreview
Started with drums, Stripped all silence from Kick and snare, some in auto some manually, treated both with Shepps Omni and S1 Fat channel, pus mixverb on the snare.
Toms, stripped all silence, plus manual editing, Omni channel and Fat channel again, panned Hi / Mid / Low
OH LR panned, no FX.
All drums sent to Bus, Omni Bus compression and slight reverb.
Rhythm Gtrs, dusplicated track, panned LR with -15ms / +15ms delay / advance to add width, added S1 Fat channel for Comp. EQ etc.
Lead Gtr - Kept central, Fat channel, some Beat delay, Abbey Rd Reverb and slight widening.
Vocal - Duplicated track, original down the middle, duplicate hard right with advance 10ms low in the mix, tread with Waves RVox, Omni channel, Mixverb, Pro EQ.
Main Bus - Post Limiter +1Db, EQ to Hi Pass, DBX 160 compression ( light comp), Abbey Rd Vinyl grit.
Hope you like it !
