I has full track with only vocals left to add...
Better check I can sing it in the key I've gone for
And just because it was done quickly doesn't mean it's good!
Oops. That was close. I'd transposed it to E and ended up needing to sing most of the choruses up the octave rather than in the lower register for the right effect.... Literally just manage to push out the top notes. I think I couldn't have gone any higher without falsetto
covers@thefretboard.co.uk
@poopot has very kindly set it up and is the one overseeing the emails so tag him if you have any related queries.
My OP stated we'd wait until all entries are in before posting a playlist. I think that the surprise element could be better for this challenge. But there's no reason we couldn't post entries as they arrive as that can give people idea and keep the threads fresh. Happy to go with the majority on this
I'm still in for this one, I've got my "influences" pretty straight in my head now I think but I do need to learn the solo on guitar rather than synth I think.
The tune doesn't seem too bad, for those considering singing, there's not a lot of range to it and it's just a case of picking the right key I think. I think I'm in D or E at the moment but that is subject to change when I add the vocal effects as to what sounds better...
I think I've written I think too many times there. I think
soundcloud.com/thecolourbox-1
cant wait to hear the rest!.
. I then discovered I needed to sing the chorus up the octave for the right effect. I just managed it without falsetto as there are lots of G# and F#s. It's easy if you sing it in the lower register but that might struggle to cut through depending on the guitar tone you use.
i did mine in the original key and the chorus was either too low or too high... went with both in the end
Look forward to hearing what you come up with. FWIW I ended up going with cheesy dads soft rock and poopot went with sleazy funk
