WTB Bass PJ pickup set
TTonyTTony Frets: 27704
The obvious contenders are the SD Quarterpounders or the DiMarzio set.
Prefer a pair that'll work well together.
I'm a very part-time bassist which is why I'd prefer not to spend on a new set.
Anyone got anything?
  • DodgeDodge Frets: 1447
    The Toneriders are pretty nice for the cash.
  • FunkfingersFunkfingers Frets: 14581
    How expensive is the host instrument?
  • TTonyTTony Frets: 27704
    Not sure how thats relevant, but about £300.
    I was trying to get a handle on how little money you were hoping to spend on pickups.  :3
    Ahh - that's a different question!
    I know I can buy new, and good (DiMarzio/SD/EMG), for £120ish.  That's pushing the spend a bit higher than I wanted to go, so I was hoping to uncover a s/h set.
    There doesn't seem to be much available between the £25 cheapo sets on eBay and the £120 options.
    If all else fails, then it might be £30 for a Tonerider J unit, and *hope* that works with the P unit that's already in there.    I'm failing to find a Tonerider PJ set (new) anywhere.
    TTony said:
     DiMarzio/SD/EMG for £120ish ... pushing the spend a bit higher than I wanted to go, so I was hoping to uncover a s/h set.
    That is what I was hoping you meant. I am toying with the idea of letting my EMG-GZR PJ pair go.
    Last call - else I'm going to check out the cheapies on evilBay ...
