50's LPC restoration
I'm aware I have mentioned this a few times, but never stated a thread.
It came to me looking like this
At some point the binding had been replaced by 4 thick white strips front and back, then painted over white too
it was refinished and a few parts changed along the way.   There was also a suspicion of some neck work, which I have now confirmed was a heel end break.
Blacklight showed a few interesting bit
The refinish glows, which alogn with the wear shows  it was all done quite a while ago
some bits of original lacquer remained, like where the finish was scraped back after the rebind shown here
or on the heel where you can see some evidence  of the break
or this rather worrying patch that looks like a screw head.   Pretty much invisible in normal light.   I can confirm it was not a screw head, just a drop fill that has melted the old lacquer into that round  shape...  the bright green is all original lacquer
The good news is that all the old structural work was done really well.  The guitar has been solid for a long time.
  • WezVWezV Frets: 16791
    First step was to get that old binding off, which went really well
    Nice clean channels for the most part
    and a hint of original binding hiding under the fretboard
    and new binding  gets shaped to fit before any glue goes near it
    We also finally get a good look at that old neck break
    some damage to the front of the body
    and that brings us up to date
  • fftcfftc Frets: 559
    Fascinating seeing the way the binding is L shaped on this style.
    Are you re-doing the neck as well to sort out that split?
    I have repaired the neck binding rather than replace it.  The splits have been repaired with binding goop
  • Winny_PoohWinny_Pooh Frets: 7802
    So the original finish was black. So then probably stripped and was then refinished to black again?
  • TTonyTTony Frets: 27697
    You *are* a craftsman.
    edited August 2018
    Yes, but i don’t think it was stripped.   Presumably the damage to the neck heel killed the binding and it all got finished over when it was all repaired
  • PhilKingPhilKing Frets: 1495
    It's looking great Wes.  It always sounded good and never had any tuning issues, so I was sure the old repair was good.  The one thing you didn't mention was the hold drilled into the body for the pickguard screw.
    Yeah.  now plugged.   I think i will just shorten the bolt rather than re-drill the hole :)
    Lets have some  more pics
  • SteveFSteveF Frets: 539
    This looks great - looking forward to following this one. :)
  • OilCityPickupsOilCityPickups Frets: 10698
    edited August 2018 tFB Trader
    beautiful job Wez ... and well photographed too mate :-)
    The poor old girl must have taken one hell of a tumble in her distant past to do that neck heel/front damage.
  • mudslide73mudslide73 Frets: 3094
    Great documentation Wez. I love these threads of yours because it's all so normal for you - Great explanations for the decisions too.
    The most confusing bit for me is the repair was done so well, but they clearly gave up on the binding.     Similar with the plugged bridge posts.   They looked badly done because they had not been finished correctly, but actually they were fit and grain matched quite well   The result was a solid guitar that plays well and sounds good
    I don't know if I would class this one as normal, but I am really happy to have the chance to do this one.
    My own custom build has been delayed as its now been rebound twice.   First go was fine, but it made sense to try a few repair techniques on something with less value first.  I managed to get a much better technique sorted before working on this
    I have done plenty of binding work before these, but never more than 4 ply.  7 is a whole different challenge.
    still a few bits to perfect before i start on  some tinting and clear,but i couldn't resist a quick mockup
  • ICBMICBM Frets: 72665
    That looks fabulous :).
    If it was me I'd go for a very light tint, subtle ageing and no 'damage' - there's just the right amount of wear on the gold to make it look like it's been better cared-for than it actually has. And no pickguard unless you can get an original... a flat shiny one like it had before just won't look right.
    But not my guitar so feel free to ignore me ;).
    I think the wear and colour on the headstock will dictate the tint and wear I add to the rest.
    2 options on the guard.  First will be one I make and age from scratch.  Second is making one from a 50’s archtop guard.
  • robertyroberty Frets: 10895
    edited September 2018
    Fabulous is the word, I concur!
  • DanielsguitarsDanielsguitars Frets: 3301
    Really nice work Wez, looking forward to seeing this finished
    www.danielsguitars.co.uk
    (formerly customkits)
    That's looking great Wes.  So much better that it was a few month's ago.  It was gigged for years (not by me), with Ian Hunter.  I got it from James Mastro, who has worked with Ian for many year, besides working with many other artists (https://www.njarts.net/uncategorized/ian-hunter-adds-impressive-legacy-help-james-mastro/).  When he got it the refin had already been done, so not sure when the guitar was damaged.  However it is a great player and sounds awesome.
    found  some pics. you mentioned the Ian Hunter connection but i don't think i caught the guitarists name
    2010
    2004
