Does anyone know what switch Gibson use for the pickup selector on a Les Paul, specifically the Tribute model if that makes a difference?
I love it so much how it's so easy to switch, just takes the tiniest bit of pressure. On my PRS Bernie the switch is very stiff and takes quite a bit of pressure so it's not as easy to quickly switch between notes.
I did try putting in a Switchcraft when I first got it but the switch completely broke. I've been assured it's an anomaly and that Switchcraft are great but if Gibson use something else I'd try that as I really do like the feel.
Cheers!
If you’re careful you can adjust the switch you have, by bending the ends of the spring pieces slightly. It can be tricky to get right though...
If you ever fancy more than three switching options, consider the Freeway 3x3-03 six-way switch. With four-conductor + shield humbuckers, all sorts of clever coil combinations become possible. No faffing about with push-pull pots.
Cheers man
Today I re-wired it all with a Switchcraft switch. The action of the switch feels great, just like my Gibson.
Luckily I was doing the bending with the plan of "if it doesn't work I'll just replace it" but if anyone reading this would rather not buy a new one, might want to watch out when trying to bend the existing one!
https://sixstringsupplies.co.uk/
Our YouTube Channel for handy "How-To" Wiring Tutorials
Why can’t companies just keep
making things properly instead of always trying to cut corners?
It just costs that much to make a product of that quality and reliability, and if you try to cut corners you lose one or both those things.
... rock’n’roll .
If you’ve seen Pete Townsend using the toggle switch on his guitar as a kill-switch, you’ll know why .
