Generally cutting an accurate route is more difficult than cutting the shape in shell/plastic/recon stone etc....
Instagram
First I machined pockets into a fretboard blank using a small (3mm?) ball-end cutter and filled them with casting resin with some mica flakes in it for pearlescence:
http://www.monkeyfx.co.uk/pictures/builds/oct-12/P1020999.jpg
Then machined the fretboard radius:
http://www.monkeyfx.co.uk/pictures/builds/oct-12/P1030009.jpg
Then the fret slots:
http://www.monkeyfx.co.uk/pictures/builds/oct-12/P1030012.jpg
Then the perimeter:
http://www.monkeyfx.co.uk/pictures/builds/oct-12/P1030013.jpg
And it looks like this on a neck (I was also trying out doing the rolled fretboard edges with the CNC machine, less successfully):
http://www.monkeyfx.co.uk/pictures/builds/oct-12/P1030032.jpg
CNC machine - amazing kit to have.
You don't see all the hilarious mistakes I make though.
I'll have a look for the resin I used - went through a few to find a good/easy one.
