What Is The Guitar Industry’s Obsession With The Past?
    Progress doesn't always equate to better.
    Some of the best sounding guitars I've played have been 50s and 60s designs.
  • FretwiredFretwired Frets: 24602
    edited November 2018
    AlexC said:
    Like a lot of you - I’m taking a wild guess here! - I spend quite a lot of time online looking at gear I can’t afford. And I’ve realised that well over half of guitars and related equipment take a huge delight in telling us that they are just like something from the 60s/70s. Or use valves. Or are a classic design. Or use pick ups that were designed in 1959. Etc, etc.
    Pedals give you that ‘classic sound’ just like 1972 or the 80s.
    You too can recreate the vibe and tones of 1975 with this vast array of thousands of quids worth of gear...
    WTF?
    Is this a marketing thing aimed at the middle aged because they’re the ones with (supposedly) a disposable income, or is it a form of laziness on the maker’s behalf?
    If everything is retro then I cannot really see how guitar playing can progress. No wonder teens are saying “screw that” and finding other ways to make music.
    Next up - the harpsichord revival.
    Take a Strat ... great design, works well, sounds great, is affordable and is easy to maintain. Why change it?
    The same could be said of violins ... perhaps the basic design of the guitar and the violin works. Yes there will be some quirky designs but there are about 6 or 7 classic electric guitar designs .. everything else is just a variation.
    Most guitar bands will hanker after the tones of yesteryear unless you're a metal player. There's a real retro-vibe with many of the new bands I see so I don't think it's all about selling guitars to middle aged farts.
    And more women than ever are picking up guitar (The Times) and Fender is seeing a sales boom, with girls favouring the Tele and Strat.
  • They’re not an acoustic instrument... they’re part of a chain of things that makes up ‘tone’.
    Most of the other gear will have been dialled in referencing classic guitars, ie what was available.
    Guitar speakers are very coloured for starters - not flat at all.
    I think theres probably a limit to how far you can stray from a ‘normal’ sounding guitar before it doesn’t work with the rest of the signal chain.
  • impmannimpmann Frets: 12694
    ICBM said:
    impmann said:
    Tbh, one of the most incredible instruments I’ve ever played was a Parker Fly - so even string to string, so much sustain, great tone, superb ergonomics
    You must be a totally different shape from me .
    And have very different ears.
    Probably. After all you like Boss Chorus and Rickenbackers... No accounting for taste. ;-)
    Then again, if we all liked the same things...
  • AlexCAlexC Frets: 2396
    impmann said:
    ICBM said:
    You must be a totally different shape from me :).
    Probably.
    ...They’d sell out very quickly.
  • ICBM said:
    . A good example is the Parker Fly - on paper the feature set looked like it should be excellent. In practice, it was hideously ugly, needlessly uncomfortable, sounded awful and had some serious durability (frets) and upgradability (pickups) problems.
    Have you really played one?
    I like the looks which is down to opinion but the rest.
    They weigh 4lb, they are perfectly balanced on a strap.
    The comfort thing is only an issue if you slouch when you sit down with one.
    Sound wise they are great. The most balanced output I've ever heard and none of the mid hump you usually get from a humbucker.
    The fret thing isn't as common as you make it. There are loads of members on the Parker forum that are still on their original frets.
    The pickups can be swapped as well. It's not as difficult as you are making out.
    Most of your points are sounding like opinion being passed off as fact
    You missed the obvious retort
    "A Ric 4001/3 is:
    Ugly with it's odd combo of waves and curves
    Needlessly uncomfortable with it's non-bevelled stick-in-your-ribs binding
    Sound pretty awful
    Have durability issues (on the bridge especially and that lacquered fretboard.. sheesh!)
    Are a pain in the butt to upgrade the pickups"
    You'll know now for next time D
  • ICBMICBM Frets: 72800
    Yes, several, although only two of the original model I think.
    Not for me it wasn't. That point of the 'hook' has a nasty tendency to catch in the notch of my sternum - that might be due to my height or the particular way I hold it, but nevertheless it is *not* a good ergonomic design if it does that to anyone - it could so easily have been avoided by having a smooth curve there - like almost every other guitar.
    You should see a woman try to play one...
    I really disliked the sound, and found it very middy in a bad way.
    Probably. I'm sure there are people with original Marshall DSLs that have never failed too ;).
    But it's more difficult than it needs to be.
    Most of your points are sounding like opinion being passed off as fact.
    Just like everything anybody likes or dislikes about any instrument really... apart from the headstock design, which *does* make it impossible to put on a normal hanger.
    The point I was making isn't so much about one guitar design anyway - it's that a lot of it was needlessly different for the sake of it, and that doesn't make it a good innovation, it makes it a bad one. That's why so many players stick with what they know - because they don't want two steps forward and five back.
    "A Ric 4001/3 is:
    Sound pretty awful
    All true of course :).
    @ICBM - it took every bit of self control I have in me not to reply to each of your points above with a *cough* Ric 4001 *cough* answer.. :D
    I hope you appreciate the gargantuan level of self control
    If it ain't broke, don't fix it - is my philosophy.
  • WolfetoneWolfetone Frets: 1479
    I don't think that it's the industry being lazy. They just go where the money is.
  • NelsonPNelsonP Frets: 3412
    I don't get the point of this thread. There have been some massive changes over the years.
    For example:
    Past
    Present
    For example:
    Past
    Present
    That’s this thread done then.
    @ICBM - on an on-topic, but also slightly off-topic note - I wondered if you’d seen Kip Wingers Spector Bass:
    Somthing raaaaaather familiar about that shape.. but yet also rather different too ;)
    As it happens - I really quite like it...
    The body shape is dead-on I think. Is that a recent thing? I can't imagine a certain litigious company will be very happy about it!
  • Are those EMGs with a reverse P? I actually kind of like it.
    Apparently it was a one-off and it is indeed a dead on copy of the body shape (including the patented surf-wave thing).
    Interestingly though it wasn’t made by Spector in the US but by their Far East distributor/manufacturer - thus neatly avoiding any over zealous lawyer waving.. I doubt it would make production though, which is a shame as it’s the nicest Ric shaped bass I’ve seen to date.
    Spector do use EMGs a lot, but they also use Aguilars too - wouldn’t surprise me if this was a custom wound Aguilar set for a really gritty tone
    Here's another
    Past
    ...and 30 years later, present:
    To be fair the differences are harder to spot on this one.
  • munckeemunckee Frets: 12460
    NelsonP said:
    Here's another
    Past
    The new one is a lot bigger
