action height on stratocaster
  • I knew a tech who used to make shims from pieces of old drum heads. As they’re quite thin you can stack them for fine adjustment.
  • rossirossi Frets: 1710
    have you tried using the trem claw to pull the trem block back and lower ?its all part of  the set up .
    i did have a llok but im not that familiar with strat floating bridge setups but i will have a closer look
