Do you use Major Scale MODES? Do you really understand them?
  • vizviz Frets: 10759
    yes and No! @viz ;
    :) ah the king of the major pentatonic speaks!
  • viz said:
    FarleyUK said:
    Can be bloody confusing though - I take the approach of playing a pentatonic, and then adding in the relevant modal notes as required. Well, in theory anyway....
    Which is exactly correct :)
    the 4 and 7 for major penta, the 2 and 6 for minor penta.
    Put very succinctly and my approach in a nutshell.
    It's not a competition.
  • FarleyUKFarleyUK Frets: 2445
    You mean..... I've been doing something right?? :)
  • RolandRoland Frets: 8816
    Well I think you have.
    Yes and if you take major penta and raise the 4th but lower the 7th you get the overtone scale; ans if you take minor penta and raise the 6th but lower the 2nd you get dorian b2; both of these are modes of the melodic minor scale :)
  • sev112sev112 Frets: 2823
    Another long thread on modes.
    i can play the, all, I can remember them, I know why they exist, and I know they apparently have different feel
    still haven’t got a clue how to use them in day to day playing
    Just play something with them and see what pops out.
    edited February 2019
    Viz, I’ve always found this “added note” approach a much more sensible way to think of modes. The dry “this is the TTS sequence” or “this is the fingering pattern” are dry text book stuff. Easy to show off with, or ask exam questions about, but of little value in playing music. If you learn scales then you play scales. If you learn finger patterns then that’s what you play. However, if you know what each note sounds like then you can play creatively.
    I appreciate that, but it doesn’t help
    i can noodle til the cows come home
    and certainly since the recent post of Modal something or other which basically says you can just pick any note you want anywhere on the neck because it belongs to a different chord that’s not in the scale or progression and that’s fine !?
    is it the chord that you are playing over or the progression which defines / suggests the mode ?
    e.g. Am C Dm sounds like A Aeolian, by might be Dorian?
    What if I stick E7 on the end ?  E7 isn’t in the scale above, so can I just play E Mixolydian over that chord because A aeolian doesn’t suit it?
    im not looking for that specific answer, but can you see that’s what I mean when I ask “how you use them”?
    FarleyUK said:
    Interesting reading through the comments here; I've only recently starting looking at modes, and it was interesting to note that I actually mostly play mixolydian.... without ever realising I was doing it! Just seemed to sound 'right' for what I was doing.
    Once I know the Key of the harmony I find the tonic and the dominant, and then decide which note I want to start on (it can be any note in the major scale). From there I see what other notes fit, and as mentioned above I anchor it in relation to the tonic and the dominant. So I am basically playing by ear, but also constructing a scale that fits the harmony. It's probably not a good idea to explain it in a book, but it works for me
    Yep I see.
    I think the missing link for you could be the chords.
    You know Dorian is Aeolian but with a raised 6th. But so what? You noodle away in dorian but why, and so what?
    Well maybe this is interesting for you:
    If Dorian has a raised 6th, what does that tell you about the chords underneath? The most important chord in dorian (apart from the minor i chord) is that it has a MAJOR IV chord!!! It can’t have a minor iv, because then the raised 6th would be absent.
    So in your example above, Am, C, Dm, that can never be dorian because the iv chord is minor. It’s gotta be Aeolian. But as soon as you hear minor i and major IV, it’s Dorian.
    Here are some examples:
    Hank: Apache
    https://youtu.be/EzgbcyfJgfQ
    DLR: Coconut Grove
    https://youtu.be/kQZQ38mO3OA
    The Mission: dancing barefoot
    https://youtu.be/f7yDGjxeX2U
    Venus
    https://youtu.be/d4-1ASpdT1Y
    You know each mode has a signature notes in the scale but they all also have signature harmonies:
    Major I and Major II? Lydian.
    Major I and Major bVII? Mixolydian.
    Minor i and minor iv? Aeolian
    Minor i and Major IV? Dorian
    Minor i and minor vii? Phrygian.
    Is that of interest?
    ... is it the chord that you are playing over or the progression which defines / suggests the mode ?
    Modes don’t tell you which notes to play. They are an academic explanation of the notes you have played. At best they tell you what are the safe notes. So if you’re playing C major and you put in a flattened 7th note (Bb) instead of the natural 7th (B) then someone could say that you’ve used the A mixolydian mode. Actually what you’ve done is just used a flattened 7th because it suited what you were playing.
    If you’re playing in a minor key then the analysis can rapidly get more complicated. There are a lot of different notes that you can throw in without sounding strange. The Pink Panther theme is a good example.  Depending on how you choose to analyse it those notes can either be called incidentals, or you’ve moved between Aeolian, Locrian, and melodic minor scales. In truth all you’ve done is played in a minor key and thrown in some melodic interest.
  • kelpbedskelpbeds Frets: 189
    The chord defines the  mode, not the progression.
    Check out my Blues lessons channel at:  https://www.youtube.com/channel/UCBTSHf5NqVQDz0LzW2PC1Lw
    Thanks - 3 very helpful posts :)
  • close2uclose2u Frets: 997
  • I like that video as it does help to hear how the modes can sound.
    I think a lot of confusion about modes is down to a misconception that they are 'scales'.  They are not scales. Scales have a number of key features some of which are common to all scales and some make certain scales unique (i.e. the Diatonic scales - Major  & its relative Natural Minor).  The 'core' common feature of any scale is that it has a 'tonal centre' i.e. a tonic note, around which all other notes in the scale consistently and predictably interact in terms of our hearing/recognition of that scale.  That is why the human ear recognises a scale and is able to differentiate one scale from another.
    Modes, however, are not scales* as they do not have their own tonal centre - that is determined by the parent (Major) scale and its key signature.  What they do have, however, is a unique tonal quality.  This is due to two factors.  Firstly, the different scale intervals they possess relative to each other and the parent (Major) scale.  Secondly,  the effect of the scale's tonic note shifting its position (between 1 and 7) within each mode and, consequently, performing a different modal tonal function (Tonic, Supertonic, Mediant, Sub-Dominant, Dominant, Sub-Mediant, Leading/Sub-tonic) within each mode relative to the parent (Major) scale and each other.  These 2 interactive factors are what makes each mode sound/feel different even though the same scale notes are being played. No book or online source I found on the subject of major scale modes ever explained that yet how can modes be properly understood or explored without having a clear perspective on what they are and why they sound the way they do?  I deduced that myself from writing my book via a logical (to me) and structured analysis of  what the major scale is, how the modes are derived from it and how they work/sound in relation to it and each other.  Of course, the above perspective focuses on the 'Melodic' or 'Horizontal' dimension of modes i.e. playing notes as a melody line.  The 'Harmonic' or 'Vertical' dimension of modes is a much more complex matter as witnessed by the many contributions to this thread so far.
    *The question of what modes are if they are not scales is also explored in my book.  Of course, they are simply 'Modes' but for reasons explained in my book I prefer to call them 'Root Variants' (of the parent scale) because that is the way I see them logically working in relation to the (Major) scale and each other.
    another video where a more knowledgeable and talented person than me attempts to explain modes using subjective feelings for what something sounds like .
    We get people saying Aeolian is Blues, that Dorian is Dave Gimour, Mixo... is rock etc etc. On top of major being “happy” and minor being “unhappy”
    I cannot believe it is this subjective if they have been a key part of music theory for hundreds of years.  There must be some science to them?
    what I’d really like to know is how they taught modes to young Herr Beethoven, Signore Rossini and young Comrade Tchaikovsky when they were moving past grade 5 theory in their primary schools in 1647 or whenever they were around
    “ok children, today we are doing the Aeolian mode.  To use the Aeolian mode you have to imagine that you have been subjected to hundreds of years of slavery and this allows you to play a minor 3rd note alongside a major chord, and if you combine it with the 5th it will remind you of the steam trains which will provide your route to escape from your miserable life, if you can imagine what a steam train is”
    or
    “in 300 years time the only people who will have long wavy hair like you currently have will be outcasts of society, who will play a special type of lute which makes much more noise than you think is possible using something called electricity but which makes the noise sound very muffled and like a loud squeal of a pig being slaughtered.  If you can imagine the music of those peoples, that is the Mixolydian”
    So so can anyone point me to a reference which explains how they taught modes to the classical composers ?
    edited March 2019
    I was jamming last night in Am, so I identified the tonic and the dominant, and then I decided to start my melody line on the 7/G, because it sounded great against the chord progression I was using. I didn't really care what mode I was in, as I had already plotted out all the usable notes that sounded good in that context. I like to construct sound palettes, consisting of both note values and timbres, and then work within those constraints. The secret is knowing when to use chord tones and non-chord tones, and I usually chart my stuff when I get past the messing about stage, as it helps with arranging/orchestration. I think I am typical of a self-taught person, as I have constructed a system that meets my own personal needs, and I'm not even sure if it would be easily understood by other players. In that sense formal music theory is useful, as it is a common language.
    edited March 2019
    Hi dude - thanks for such an interesting post! I have a contrary point to make, which is that modes can be thought of relatively (as in, relative to their parent major or minor scale), or absolutely, as scales in their own right. There are 462 heptatonic scales, of which major, minor, dorian, phrygian, lydian, mixolydian and locrian are but 7 (the 7 diatonic scales by the way).
    They are all heptatonic scales (from the Italian scala meaning ladder) because they all have a root note and 7 rungs to the octave above. Sure they are similar to major and minor (as are harmonic and melodic minor scales), but that is only one feature of them - it doesn’t mean they aren’t scales in their own right.
    i think the best way to discuss those modes is a) as for example a flat 7 palette of notes in V position, and b) as a mixolydian scale on which to base a piece.
    Summary: you can think of modes in two ways.
  • Hi dude - thanks for such an interesting post! I have a contrary point to make, which is that modes can be thought of relatively (as in, relative to their parent major or minor scale), or absolutely, as scales in their own right. There are 462 heptatonic scales, of which major, minor, dorian, phrygian, lydian, mixolydian and locrian are but 7 (the 7 diatonic scales by the way).
    Thanks viz.
    Your perspective made me think back to how I tried in my book to logically reconcile (for myself) what music theory defines as 'scales' and what it says about 'modes'.  'Scales' have plenty of consistent definitions in the literature.  'Modes' on the other hand abound with inconsistent, confusing and contradictory literature.
    So i started with what the theory books say about the Major Scale i.e. diatonic(notes are relative to a tonal centre), all natural notes, 5 full and 2 half tone steps, etc.  Then I asked myself can modes also be scales if they exist only within the context of the (Major) scale? If the scale is defined by its tonic note(the key signature) how can each of the modes also be scales in themselves when they (6 of them) actually are defined by a 'root' note other than the (Major Scale) 'tonic' note? There is an inherent contradiction there which I could only reconcile by not thinking of modes as 'scales' but as something else, which I call 'root variants' (of the major scale).
    I developed this reconciliation in my book by exploring beyond the general conventional wisdom that modes sound different simply because they have different intervals.  I suggest that they also sound different because the tonal centre, 'tonic' note (of the Major Scale) shifts position sequentially and changes its tonality function within each mode. I have not found that analysis anywhere else and, of course, my interpretation could be flawed.
    However, despite my attempt at a theoretical explanation I accept that, in practical terms, .we treat modes as scales in the way we play them.
    Coming from a semi-scientific background I find music theory to be a pandora's box of such contradictions and unexplained and unproven assertions and yet, given its mathematical foundations I don't follow why this should be so.  However, I am really just a belated beginner on my musical journey so perhaps I'm expecting too much.
