From memory, the spec Line 6 are looking for with this unit is a tip/sleeve connection with a 10KOhm linear potentiometer in the pedal.
People say they can get other pedals working with it, but you never really know if they're getting the full range of CC values being calculated from the full range use of the pedal. I've heard people say things like "I use it as a volume pedal but it never goes totally quiet".
http://thefretboard.co.uk/discussion/155061/fs-2x-mission-engineering-ep-1-black-expression-pedals
He's a very nice chap. You should buy it from him.
Yep EP-1 is a great expression pedal. Yours if you want it @relic245
Thanks, I want but mostly for home use this is probably a bit over engineered for my needs. also a bit over budget
Thanks, thats a good price but I feel a bit uncomfortable buying it if you're not 100% sure that it's working.
