Nux drive force
£38 and every drive model known to man
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
Most guitar stuff seems to be like that (the things which sound best are actually technically worse) )
Yeah same here, I didn't mean to be rude, I just thought it was funny.
That's a good point about the SD1, now you mention it I remember seeing on the schematic that it used a 4558 too. Woops )
I wonder if the blue sky is actually a timmy clone- by that I mean, has anyone actually reverse-engineered it or are they just going by the knobs? I only ask because the orange burst stonevibe mentioned is (far as I'm aware) an xotic BB clone, so that being the case the blue sky could easily be an RC or AC boost clone rather than a timmy clone, as the knobs are the same- and if my mooer pure boost (RC clone) and dano timmy clones are anything to go by, they sound very close indeed to each other, you could easily confuse one for the other if you hadn't reversed the circuit to know for sure.
Obviously if someone has actually reversed it and found it to be a timmy clone that's different- just a lot of the time you see things being claimed to be clones with little actual evidence behind the claims and they often turn out to be clones of something else instead. )
TODV1 is a brilliant pedal, and even the V2 one is great for the price too!
I'm selling my V1 at the momemt though as I've got a Tim clone that I've been using more. I've A/B'd them and I can't hear any difference!
Guv'nor Mk2 is also a keeper, it can get VERY close to a lot of the channels on my JVM. Great pedal to have just in case I need to use a different amp at any time!
I've also got a Boss SD-2 Dual Overdrive - there's been a few listed on e-bay recently that have gone for arounf £40. These are great pedals, very versatile/compact
Joyo AC Tone - until I played the Wampler Ace Thirty, this was the best Vox In a Box I had tried! I think all the pedals from this range deserve a lot of praise, great tweakability as well as being able to connect them straight to a PA or a PC for direct recording (The Rocktonics range are exactly the same pedals too, I had both the AC versions and they were great!)
