This is something i haven’t encountered before...
Guitar in question is a Furch baritone. And it is a bit rattly. Even when played lightly.
Being new to baritones I had initially put this down to the longer scale and heavier strings. Then having had a closer look at the relief and saddle height I was surprised to learn that the source of much of the rattle is actually the nut... even when playing barre chords up the neck.
if I put a capo behind the nut, increasing the down force a bit like a string tree 90% of the buzz disappears...
I know if I were to add a few winds on the strings at the next change, this would likely solve the issue by creating more downforce. but potentially causing stretching/tuning issues to appear.
So should I be looking at modifying the nut in some way? Thinking ramping the slots or something. Happy to give this a go if it will solve the issue. But don’t want to go there (and potentially mess up) if it isn’t going to make a difference.
After the cost of £7 for a new bone nut after I had muffed it up it only cost me an additional £90 to get a luthier to install it, set it up and polish it.
Try winding the strings further down the posts. It may well cure the problem without needing to do anything else. I'm normally a big advocate of using the minimum amount of wrap on the posts to avoid tuning issues, but there are some you can't do this with - especially the G string on a Fender-style headstock with no second string tree.
