Tested it out - all knobs work ok - the only difference in mine is that the gate knob on the diagram acts as a volume on mine and the vol knob on the diagram is a gate.
Either way it seems to be very good - certainly compares to the fuzz barn i had previously.
Happy days.
After i housed it up it stopped working - passes a clean sound but no fuzz whatsoever - i'll trace the wiring after work tmoz - sounded good when it worked though.
So, if i test it unhoused and touch the stab knob across the wire contacts it works fine but as soon as i house it in the metal enclosure all i get is a clean signal - guessing there's an earthing issue - should i solder a wire directly from the stab knob to earth?
What DC socket are you using?
What pots are you using?
Pics would be helpful if you can.
Its battery only - and i'm using 5k and 10k as in the layout.
Sorry I actually meant as in lug or pcb - basically I was asking as along the lines of what ICBM just asked.
Is it possible to remove/install pots one at a time to see if one is causing the problem?
Also, when installed there aren't any wires being over-bent or connections strained are there?
