I recently picked up an Ibanez TMB100 - love it, almost too good for the price, but I’ve noticed that on the low E I have to be very careful to play close to the bridge and to pull the string fairly vertically rather than toward me when I play ( I use index and middle fingers ) or the note will be sharp on the attack and take fairly long to settle to correct pitch.
Is this purely a technique thing or a setup / string gauge issue ?
I’m not really a bass player, I used to have a 5 string Yamaha some years ago and can play reasonably simple parts but that’s it.
It might be worth examining how accurately the string sits in the nut slot and the bridge saddle groove. (Filing issues.) It might help to know what brand of string is on the instrument and how old they are. (Fatigue issues.)
Other than that, my solution would be to switch off the tuner display and cease obsessing about these things.
The nut and intonation are fine, I can play in tune if I’m very careful with my right hand but I can’t play as loud as the other strings.
The strings are the new factory ones and seem fairly decent.
It could be purely down to my technique but I’m not experienced enough to know.
Now I've got 45 - 105 and it's a lot better.
I looked up the strings and they are already 45-105, but I might put some flat wounds on which should be higher tension and more my kind of sound anyway.
In any case it’s gone with the new set of flatwounds, which also made the bass sound even better.
