The key of F is not the key of F#b “F sharp flat” - that doesn’t make sense.
G (1 sharp)
D (2 sharps)
A (etc)
E
B
F# (6 sharps)
C#
Anticlockwise, in green, you have all the “flat keys” - the ones that deploy at least 1 flat. F is just to the left of C and has one flat, as you rightly said.
F (1 flat)
Bb (2 flats)
Eb (etc)
Ab
Db
Gb
Cb
my original ‘rule of 7’ is that if you know the number of sharps in, say, D (2), you can calculate the number of flats in Db (5).
Genuinely no offence meant, @viz clearly knows his stuff.
Yup, modal music is so comparatively rare in classical music it can be totally skipped by many musicians. But keys and 4ths and 5ths can’t!
What do you think?
https://youtu.be/m9KOuQmNXD0
Feedback
