You could also try a diagonal 2x12, which is tall enough to wheel around
Well! You know where I come from and what my ID.ea will be?
Dave.
My 2 x 12 is already loaded with V30's, i'd be tempted to try something else If I go the single 12 route, perhaps Greenback. Although the cheapest option would be to pick up an empty cab & stick one of the V30's from my 2 x 12 in it.
Do those 'neodymium' speakers sound as good as regular speakers?
Keyboards just tend to eat all available frequencies, though you may get away with it in some guitar bands.
You'll still sound shit though.
I'd echo the sentiments above about a head and a separate 1 x 12. A lot of valve combos are quite heavy - the power transformer and output transformer mean there is siginificant weight of ironwork in there. To be honest you'd probably find your existing 2 x 12 with Vintage Centurys in would be lighter than a HRD.
The other options are modelling and/or going direct. Something like the Blackstar ID mentioned above would be a lot lighter than a valve amp of similar output. Or if you have a decent PA and monitors you could always go direct with modeller or a pedal with cab emulation on. The Sansamp ones (or the Joyo/Harley Benton knockoffs) are the obvious ones but there are other pedals with cab emulation as well.
