Also chips are "Plant-based" no matter how you cook them.
Bonkers.
The absinthes I used to drink came in between 65% and 77% and I concluded that all that guff about absinthe being hallucinogenic was bollocks and basically if you drink 65% alcohol anything you'll see whatever your poor damaged brain happens to throw at you.
Once it's over 5%ish, it will only start tasting worse.
I'd happily taste a 65% beer but I'm not sure I'd drink a whole one, or even a third. Good effort!
This one for example ...
When I worked in Brussels the running gag was for the barman in the hotel to give any new arriviste 3 of these and see if they could walk after getting off a bar stool (I failed spectacularly ) - doesn't taste strong at all, a bit chocolately if anything - hence they get necked quickly and ta da !
Feedback
