You're about to bust out a solo, what pedal(s) you stepping on?
  • SargeSarge Frets: 2433
    Switch from neck to bridge, natch.
  • andy1839andy1839 Frets: 2212
    Archer Ikon set for mainly a clean boost after a Friedman BE-OD, huge volume lift and that 'clean-but-dirty' bonamassa type sustaining lead.
  • TTBZTTBZ Frets: 2954
    LPB1 or micro amp in the fx loop. If I want more gain then a TS in front as well for mids and compression.
  • HAL9000HAL9000 Frets: 9814
    Turn the volume from 7ish to 9½ -10. Maybe fatten things up a touch with a fairly transparent overdrive (J Rockett Blue Note in my case).
  • gringopiggringopig Frets: 2648
    edited July 2020
  • Volume pedal, I usually drop my plectrum if I reach out for a knob.
  • randellarandella Frets: 4384
    On the clean side of the amp, usually set to a crunch-if-you-really-dig-in gain level, either guitar vol or SD-1. If I need more I have an EQ in the loop.
    On the drive side of the amp, EQ for volume boost and SD-1 to hit the amp a bit harder if I’m feeling pinch-harmonic fruity.
    My clean and drive channels are set for the same volume.
    Sounds a lot more confusing than it is, and is incredibly flexible.
  • merlinmerlin Frets: 6831
    Depends on the guitar and sound I'm after. KOT, Sidecar or most often, volume and/or tone pot.
  • RolandRoland Frets: 8846
    Exactly! I use one one or more of:
    1. Turning my guitar up
    2. Switching pickups.
    3. Mid boost.
    4. Drive pedal. Don’t ask, it’s a Fractal model of something or other.
    5. Changing amp settings
    6. Changing amp model
    I might also turn up the reverb and/or add delay.
  • vizviz Frets: 10771
    Mute pedal by mistake.
    9reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • Korg Miku.
    @viz Been there!
  • Wow interesting replies here!
    So for those of you who'd favour running into a clean channel of the amp, do you think this drives it harder with a pedal? Me I've always preferred amp distortion then boosting. I do have an SD-1 which acts as a nice boost.
  • Tube Screamer Mini
  • The boost channel of my amp, or more specifically, OD2 on my old Marshall Valvestate.
  • JerkMoansJerkMoans Frets: 8871
    Metal Zone \m/
    Inactivist Lefty Lawyer
  • tone1tone1 Frets: 5200
    Usually a Lego brick... =)
  • If I've been asked to play a solo...I step on the tuner so nobody can hear the inevitable car crash .
  • SquireJapanSquireJapan Frets: 723
    edited February 2020
    Caveated  by me not actually gigging ... I've found a new love in the form of my neglected DS1 (Keeley Seeing Eye Mod, I think).
    I've gone all "proggy", so I'm after the saturated high-gain. It sounds crap for rhythm, but top dollar for the widdley lead sounds. Seems to take the nice "chuggy" sound I have from the Mesa to just the right place. First time I've ever really liked a sound out of the thing ...
  • hoopshoops Frets: 234
    Twimble
