Fantastic performance by Ed Sheeran on Jools Holland last night.
I realy like to see the use of loops by an individual to create the sound of a full band.
I have tried many times to put a basic loop together and every time it sounds like two people who have never played the guitar have just decided to jam together!
How he pieces togther the loops is great but what on earth did his pedal board consist of? Looked like a large iPad with multiple pedals housed in a large box? Bigger than a BOSS RC-300 loop station!
Hats off to all you looper masters!
When I saw this on Jools Holland about 8 years ago I went a bought an RC20 the next day !
Using a looper switch is time critical in a way that most guitarists haven't experienced before. It's actually more like learning to play the drums and having to learn to co-ordinate your hands and feet. Switching a looper is a bit like playing a kick drum. As @not_the_dj said, it's usually better to play through the part a few times before 'capturing the loop' and I've also found it helps to 'ghost tap' your foot over the pedal and then just extend that action to actually hit the switch and set the loop in/out.
I've used a Line6 DL4 for years but I now have a JamMan for this new project. I've found the different switches have different responses that your switching technique needs to be adapted to. The DL4 has momentary stomp-style switches whereas the JamMan has a Boss-style pedal switch - they feel very different to operate. Going back to the kick drum analogy, it's a bit like using different kick pedals - each has it's own feel and response that you need to familiarise yourself with.
So it takes a lot of practice to learn to both accurately judge where the beat is and also to 'play' the pedal's response accurately so that you activate it at the correct point.
Great fun and a really creative tool, though. With a bit of practice.
For a fully featured looper that can do pretty much anything you might ask of it (not that I'm gassing for one, absolutely not, no way =P~) have a look at the Pigtronix Infinity.
Pretty pictures of stuff and things here...
My Feedback thread here...
