Other brands, especially those made for passive use tend to be higher.
Very well regarded maker, even if not well known.
I always thought it would be an improvement - a PJ usually has a weak-sounding and noisy bridge pickup unless it's a high-output stacked humbucking one.
It still doesn't look right though!
Sounded excellent.
I think the opposite issue is also true though - that on a J&M bass the neck J pickup can be very underpowered if not properly picked, even with the additional string movement there helping out.
My experience has always been that the P and 'Ray pickups do not blend especially well. It might be that an amp EQ setting that compliments one pickup detracts from the other.
I've read that the pickup's position means it will not sound like a MM as it's too near the bridge. I've also read, but can't confirm, that you can't physically position the P-MM pickup combination exactly as on each original instrument as they overlap slightly. That might be part of the problem, unlike the classic P-J combination.
I guess the Sandberg humbucker has more of a beefy-J pickup sound, though I am new-ish to bass so that might not be 100% correct. I generally play it in passive mode so that's another big component removed from the MM sound.
the MM would overlap the P.
@fretmeister I defo wouldn't mind a bass from that company. I've made dozens of mockups on their excellent website, often with P and M but it just made me wonder if there was a reason not to do it.
Always built very well, nice neck shape. It's all good!
The best basses I've owned have all had them.
http://configurator.sandberg-guitars.de/
I've never had a zero fret but seems like such a good idea to me.
I don't think the placement should be much of an issue, it's a couple of mm out.
The output difference might be the problem, maybe the MM pickup would have to be changed so much to match the output of the P pickup that it no longer sounds like a P.
Maybe not, maybe it's just tradition and the "looks wrong" thing that stops it being common despite being a viable option.
