Previously I'd quite often remove flatwound strings (even sometimes roundwounds) and keep them to re-use on the same bass or even other basses.
But then I did it with a set of expensive flats and when I put them back on, one of the strings was totally dead, just sounded terrible.
So currently got a different set of flats on my P bass but wanting to have another try of rounds for a while (to see if I really should get a second P or not) but don't want to ruin the strings that are on at the moment as I definitely want to put them back on after a while.
Any tips on removing and/or storing them to avoid killing the strings?
Often refitting kills them because it’s impossible to get them back on in the identical way as originally fitted. Slightly different twist or stretch in the string anywhere and they are dead, especially when using a BBOT bridge or anything else that needs the string threading through.
Its always worth a try before binning them, but success is probably only about 20%
And of course if someone likes 5 year old dead flats then there won't be any difference in the first place. To quote the Bass Whisperer himself "Change your strings every 10 years whether they need it or not!"
I feel your pain though - I have one P bass and I'm forever swapping between flats and rounds. If I find another American Special that weighs no more than 8lb then I'm having it!
I never take 2 basses though. Cannot be arsed to look like the eijit who swaps instruments each song!
I wouldn't bother with that personally. For me it's not about pennypinching, it's that I only have one Precision at the moment and want to try it out with rounds with a new band setup but don't want to waste the relatively new 45 quid flats that are on it.
To be honest I don't think I'll ever be satisfied until I have a Precision with each. Even if I end up rarely using one of them in the future, I really want a period of being able to swap between the two string types to try out in different scenarios.
