Tele jack socket loose - suggestions
sev112sev112 Frets: 2861
have a newish Squier esquire which is a great little guitar
jack socket is loose howvere
looked at the interweb and various fixes proposed which seem mutually exclusive, from taking the switch panel out and using your finger while you tighten , to buying a special tool, and several things in between
before I do either, any good experience / suggestion from the experienced masses?
Its the circular socket with a hex nut, no little Phillips screw on the side
ta v m
  • RaymondLinRaymondLin Frets: 12056
    a little drop of superglue then tighten a little with tip of finger.
  • skippy76skippy76 Frets: 619
    Morning,
    You shouldn’t need any special tools for this, pop out the two screws holding the control plate and use your finger to put pressure on the back of the jack (watch the wire connections).
    Add One drop only of loctite to the thread on the outer part (or super glue if you don’t have loctite), tighten and leave for a few minutes.
    Cheers
  • ICBMICBM Frets: 73086
    Has the cup come loose in the guitar body, or the socket come loose in the cup?
    If it’s just the socket come loose, it will be a cheap flimsy far-east socket and may not have a grip washer. Your best option is to replace it with a genuine Switchcraft jack, with a grip washer - these can stand being tightened up much tighter and will lock the whole thing together properly.
    If the cup has come loose in the body, the best solution is an Electrosocket - these are threaded for a Switchcraft jack so you would need one as well.
    If that all looks too expensive you can do it cheaply by gluing the cup into the body with epoxy, and re-using the existing jack (with a grip washer if it doesn’t have one).
    No, you should not have to do these things really!
  • munckeemunckee Frets: 12593
    Save yourself a life of pain and get a proper jack socket which screws to the outside of the body!
  • HenrytwangHenrytwang Frets: 473
    I have in the past repositioned the claw thing and fixed the problem but an Electrosocket with a Switchcraft jack socket, ( about £8 on eBay ),  is probably the best fix.
