GIBSON CS M2M dealer models
Seeing a lot of stores inc Coda that have a fair amount of M2M Gibson Les Pauls
Whats the deal on resale value and desirability with something like this?
C.O.A just says CS and the serial number as obviously it’s not a particular model with it being M2M
Ive seen a Les Paul custom one that I fancy but worried about potential resale value etc down the line given it’s a store M2M
  • JackobeanJackobean Frets: 668
    edited June 2020
    Most dealers are using the M2M program for minor tweaks - neck profiles, pickups etc.
    Unless they've ordered something in puke green with robot tuners and a bigsby,
    I doubt the resale will differ hugely from the norm.
  • RaymondLinRaymondLin Frets: 12059
    It’s harder sell to the wider public because it’s implied a specific spec and often priced higher compare to a R7/8/9.
    quality wise they should be on par.  I’d only get one if it has the spec you are after not found on the regular R.
  • FortheloveofguitarFortheloveofguitar Frets: 4294
    edited June 2020
    It’s lightly aged and uncovered pups and that’s about  it.
    I do like that but it’s over £4K so there’s definitely better value elsewhere on a used R7 Custom
