Sharing some shreddy stuff/ideas I've been working on (video/tab) - Updated!
VibetronicVibetronic Frets: 1037
edited July 2020 in Technique
Following from posting stuff in someone else's thread, I thought I'd make my own if anyone is interested. These are just little ideas I've either had for ages or have started mucking about with more in lockdown. Sound quality does get better in the last couple as I slowly figure out how to improve the audio
1) Tapping idea - using mainly two but then 4 right hand fingers. I use the pattern with two fingers all the time.
https://youtu.be/_-jTIprnQD4
tab at: https://drive.google.com/open?id=1Rn_PfJMV_gvoqld4jg8otsL0HZUB609b
2) Picking/muting thing - slight Nuno-esque.
https://youtu.be/yziGw8VqBow
tab at: https://drive.google.com/open?id=1RGxAYuI3euEDe6W0cToH-wCr6KHEYnTK
3) Picking/muting thing pt.2 but played a tiny bit better!
https://youtu.be/TCw6qEuuDXg
tab as above...
4) Another picking & muting thing using 3 nps shapes.
https://youtu.be/c2ltdAnP0tM
tab at: https://drive.google.com/open?id=1Zk2MLMC_FJovmd18CP6euTLeRFGD4RMq
5) Sweeps with taps but taps behind the sweeps. Just sounds silly so I like it
https://youtu.be/u-rzJdNoPg4
tab at: https://drive.google.com/open?id=1HrvoEUERQciJc8FFvC65q_un7RbpPsOx
6) Bending the string off the neck. Yes, it can go wrong, but when it doesn't, it's cool.
https://youtu.be/pOXze2IBAZY
no tab - you just tap on the high E and tweak it off the neck. Very carefully.
7) Couple of sweep ideas; 2nd one still in it's infancy but when it works it sounds cool.
https://youtu.be/ARnTZLeuRLc
tab at: https://drive.google.com/open?id=1BjdH_Gvsu8defPKDVOdhY95BYNjL9bag
8) Tapping shapes I use all the time. Probably too much. I forgot what I was doing in this one then suddenly remembered, hence the pause partway through! Tbh I think these are fairly commonplace but I like them!
https://youtu.be/LptdFmN5Y8c
tab at: https://drive.google.com/open?id=1z_0VFToIpF03t5z4r6rIJzebE9piY8Sb
9) More tapping ideas. First one dead easy, second one I've put up here before I think but it sounds neat and better in this one.
https://youtu.be/UiITJRI-Bsg
tab at: https://drive.google.com/open?id=1lk8APl3sXP0k1pvRpAf4qoxgTJTa8ZM6
(the bit in brackets in the second part is just something I added in by accident but kept as it sounded neat).
edit: please let me know if I've linked the wrong tab etc!
