Due to a change in direction, towards 4-strings, I have a black Kustom Coupe 36 1 x 12 for sale. Great amps designed by James Brown (I believe) who had a hand in the Peavey Classic series also. It's a twin channel amp with switchable boost and bright switches for both channels. Volume wise I'd say it keeps up with your average 40watt valve amps - Fender HRD, Peavey Classics etc etc. I actually got it to give a bit more headroom than the AC15 I had previously which it did nicely.
It's in good condition and sounds great, 4-button foot-switch and cover included. Whilst it's working fine there is an occasional background scratchy noise so could probably do with re-valving at some point in the near future (reflected in my asking price).
Specs:
Kustom ’36 Coupe
Features Dual 6L6 power tubes, 12AX7 preamp tubes, 12″ Eminence KEI12 Turbo speaker, two channels, adjustable boost circuit, long-tank spring reverb, effects loop
I'll get some pics up this evening when I'm home.
I'd like £200 + postage or you can collect from Swindon, Wilts.
(low post count on here, but some of you may remember me (!) from the old musicradar days where I had a 100% good feedback. I'm also 211dave112 on ebay with 100% feedback)
Ian - not really after trades at the moment I'm afraid. Thanks though.
It's basically a heavily upgraded Classic 30, with a massively improved lead channel, and a reverb function to beat a Fender Deluxe Reverb. They're excellent amps. Will do classic Fender Blackface, tweed tones, through to Marshall flavoured overdrive. The reverb can get as wet and drippy as you like, perfect if you want to get your 'Dick Dale' chops dusted down.
Best upgrade. Eminence Cannabis Rex.
Cheers
