Just seen a '12 step' which also looks good.
Anyways...tricky one to get my head around, it's a bit of money for what is essentially an experiment...
Cheers for the suggestions
https://www.keithmcmillen.com/press/keith-mcmillen-instruments-announces-12-step-v2-0/
http://www.theboxwoodchessmen.com/
https://www.facebook.com/tingiants/?view_public_for=231700547508938
I can upgrade to a 12 step or the Roland if things work out.
Thanks again everyone for the advice.
PK-5A
12-Step
Also all the other folks for the suggestions....a bit to think about here, it's essentially an experiment to see if we can (partially) replace some of the stuff our departed keyboard player used to do....
Need to get my head around some basics first - e.g. can I trigger the thing to 'play drone x in the key of D'. Or make the patch know what key it's in (surely can do if I program the synth)....or whether I need to have all the pedals for the notes.
I reckon I'll take a punt on the Behringer first, see if I can actually do the stuff we need...and upgrade as needed. Exciting times
I think if you want to ask @prowla a question, you can do the @ thingy...otherwise they may not see the question, esoecially if it's a bit of an old thread.
I've done that here for you, interfering busybody that I am.
Hope that's OK forum etiquette-wise....tell me if not!
In any case I am sure people will help if they can.
Plenty to keep me occupied. I'll post a update in a few days time as too how I progress.
I've now added a Roland Pro-e synth, which works pretty well. That gives me the drum machine that I can control with the PK5. However I've found the Pro-e sounds are not anyway near as good as the MSG64.
So the best sounds come when I've got the Rolls unit into the PK5 into the Pro-e, and the out and thru into the MSG64. Sound from the Pro-e is off, unless I want a sound effect.
Playing Bass along to the drum machine is great fun. I guess the next step is to create my own rhythms.
