And yes Reaper is great for it as it makes switching the thing on and off very easy so it isn’t clogging up the CPU when it’s not needed.
I also tried some other springs based on smaller units and was far from impressed.
IIRC I was recommended to try this one but couldn’t get it going on my old machine. Anything EMT by TimP or Cupwise will be good I expect - EMT plates are what it’s all about IMO.
https://www.timpetherick.co.uk/downloads/vbp-reverb/
Thanks for the info, I will check out the ones that you mentioned, they say Tim does a mean SSL bus compressor.
https://justpaste.it/AcusticaAudioAcquaMasterList
Is it a plugin within which you can load various pieces of gear? and are those pieces modelled or is it actually a series of IRs (dynamic IRs at different signal levels?) of the actual pieces of gear?
Bandcamp
Spotify, Apple et al
The best 3rd-party developers have found new ways to push the boundaries even further, and the new stuff is top notch, although the old stuff still works well.
Here is an old SOS article that may make things a little clearer ...
https://www.soundonsound.com/techniques/sample-your-gear-acustica-audio-nebula
And some background info from Wikipedia:
https://en.m.wikipedia.org/wiki/Volterra_series
If you ever decide to jump in I'd wait for the sales, and I think you can get N4 for around €79. The Acustica Audio Acqua stuff they produce themselves is standalone (no N4 required), but I prefer the approach taken by the 3rd-party developers.
There is a discussion thread on Gearslutz if you want to get into to the finer details:
https://www.gearslutz.com/board/music-computers/566552-nebula-must-have.html
Nebula is just another tool in box that some people enjoy using
If we're talking that kind of money, the Lexicon reverb plugin and Slate Verbsuite Classics.
BTW here is my UI which I have mapped to physical knobs that control the currently active plugin window.
https://mir-s3-cdn-cf.behance.net/project_modules/max_1200/e7d0a345096415.58264e40cbcc6.jpg
