Ive been tasked with doing a Jingle...
Yeah...I know....for a radio station...anyone know where I can get groovy loops in a cheesy disco style?
Mac Mini M1
Presonus Studio One V5
 https://twitter.com/spark240
Reddit r/newmusicreview
  • Definitely Splice has loads on there. The Oliver ones are great :)
  • andy_kandy_k Frets: 818
    That sounds like an exciting little project, I would approach it a little differently though.
    Do you have a definite brief?
    Is the idea meant for a station ident, ie-are there words that have to be fit to the melody?
    Time limit?
    Tempo?
    style?
    All of these things provide a backbone to build up a melody, and I would set up a project with say 3 ideas in series.
    This will allow you to work on multiple ideas with common instrumentation.
    It will at least allow you to use some originality in the idea, which might inspire.
    My point is, at least this way, you will have the satisfaction of knowing you came up with an idea, and if successful, it might lead to bigger projects, rather than sounding too generic and built on the same loops everybody uses.
    I'd use it as an opportunity to try to stand out from the crowd, somebody might notice the effort, and hopefully it will be somebody who matters.
    good luck anyway.
    This popped up in my YT today, it is a great example of taking a simple technique, and using it on a basic idea to generate unique results, I just thought of your thread when I saw it's use, only 13 mins long, but the ideas in the bank.
  • spark240spark240 Frets: 2084
    edited September 2020
    Time limit?
    Tempo?
    style?
    good luck anyway.
    Yeah..I’ve been brainstorming a bit but it’s trickier than first thought.
    This is initially a favour in return for Novum FM playing our first song, it’s a bit of a MOR station .
    the sample they  gave us was
    Disco style beat...Jackson’s style.
    around 10-12sec.long.
    we have some words to fit in.
    thanks !
    Mac Mini M1
    Thats useful,
    I would take a scattergun approach, rather than grafting over a single idea, set up a timeline with 3 or 4 regions-each 10-12 secs long, Disco has a pretty strict tempo style, and the words will indicate some kind of melody line, just have fun with it.
    You can set up instruments to mix and match across the 3 or 4 ideas you have running.
    If you have a reference track, that will indicate the type of instrumentation you should use, at least 80's synths had some rhythmic component to keep up the excitement.
    You might want a bar in and a bar out, so that cuts the time down a bit.
    Limitations can easily encourage ideas.
    At least then you could be offering them 3 or 4 quick ideas, and it could easily spark more involved things.
    Get lucky!
  • poopotpoopot Frets: 9099
    @spark240 do you use logic? That has a tonne of loops... if not, you’re on Mac right? There’s a load bundled with GarageBand!!!!
    Oh yeah !....Ill check that out thanks
    Mac Mini M1
