https://www.flickr.com/photos/190528855@N04/50431051333/
I was lucky enough to get hold of some 100 year old mahogany (1" thick and approx 9' x4') when the local school replaced their physics lab workbench, so I made these. They all have mahogany backs with some chambering to reduce weight. From the left the tops are: French white oak; plain ash; African idigbo. The neck on the green guitar is made from the same piece of mahogany, the others are maple. The second knob on the guitar on the left is actually a rotary pickup selector (I don't like tone knobs).
They all turned out pretty well but the one on the right (home-made P90's) is the one I always reach for first. Here's a picture of the back of that guitar:
https://www.flickr.com/photos/190528855@N04/50431756611/
https://www.flickr.com/photos/190528855@N04/50431051333/in/album-72157716292765813/
https://www.flickr.com/photos/190528855@N04/50431756611/in/album-72157716292765813/
Nil Satis Nisi Optimum
What finish did you use on the Idigbo? I've done a couple of Idigbo bodies so far and have used Danish Oil slurry finishing with wax top coats after reading Wez's threads here.
Like the sound of that 100-year old mahogany. I was lucky to get hold of some similar stuff from a library - enough for about 10 necks or so.
What are you going to do next ?
you do have to be careful with those science lab benches as Iroko became more common than mahogany, and its nowhere near as nice to work with. =
Instagram
It's a brush-on resin type of finish supposedly designed for domestic use. I can use it in my garage without needing special applicators or breathing apparatus - I am allergic to nitro-cellulose. It does take quite a bit of wet sanding though.
I'm currently using the last bit of Mahogany to attempt a left-handed build for a friend. Everything is upside-down and back to front so it's quite a challenge!
I used to do it in my spare room, which was daft.
Instagram
I've edited my post.
As said Plasticote is pretty bad for you but think I used it without a mask back in the day it was pretty popular as a good finish for amateur builds. One of its claims to fame was it said on the packet it would crack or yellow no good for guitars these days they all want them cracked and yellow LOL
