On the other hand , I don't particularly work with software ( especially not Edgecam as it's quite an advanced software ) , so I am in the dark a little bit
Having worked with programming CNC machines for many years making prototypes, I have grave doubts if you could ever manually input the tool path for a F hole. You would most certainly have to use some kind of technical drawing software to work out all the vectors the arcs diameters of the circles it will be a bloody nightmare, just use a CAD Cam system and it does it for you.
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
Just out of interest is your speciality coding Heidenhain I did have a quick Google and manual read seems yeah there is some powerful stuff but no less arcane than any superset of proprietary gcode control.
