I have no idea what this is called or where I can get some more of these. Can someone help please?
https://i.imgur.com/AmhFwvy.jpg
https://i.imgur.com/Ow81LyY.jpg
https://i.imgur.com/iCPzdvn.jpg
And here’s the rest of the guitar..
https://i.imgur.com/BNMVMbw.jpg
https://i.imgur.com/2l8Vm4E.jpg
I always use a scrunchie: added benefit is being able to pull it over the nut for extra muting help when doing some tricky recording
https://www.ebay.co.uk/itm/Wedgie-Bass-Guitar-Headstock-Pick-Holder-Rubber-Pick-Headstock-Guitar-Pick-H-ti/202991966822?ssPageName=STRK:MEBIDX:IT&var=503180511176&_trksid=p2057872.m2749.l2649
Consider these two objects:
The String Butler is supposed to convert all six strings into passing along straight lines across the headstock.
anyway, changed to klusons and it's all good.
That said the String Butler is a horribly ugly, over-complex solution which causes other problems including adding mass, which is not necessarily a good thing. From the only one I've come across actually fitted to a guitar it doesn't even fix the problem anyway - proper cutting of the grooves and lubrication is still more effective.
