Apart from one of me aged about 3 with my sister's acoustic:
http://img.photobucket.com/albums/v349/Lixarto/img127.jpg
http://i238.photobucket.com/albums/ff193/guitarsforminnaars/imagejpg1-23.jpg
Nowthen......who do I know that has a Scanner....?
1974 with my mate Ben on a Ned Callan bass and yours truly on the Woolworthscaster.
It started out as one of these,
and then one of the PUs died, so I swapped it for a cheap 70s no name humbucker after hacking out the top with a key hole saw!. A while later I replaced the front single coil with another cheap humbucker and hacked a further hole to put the single coil in the middle. one mini toggle switch was added then too. The trem arm was useless so I just took out the naff spring and put in a block of hardwood and removed the arm. I learned a lot (both playing and updating) with that guitar, it was a valuable tool which I carelessly sold for £15 some time later. I was given my first semi pro lead guitarists job despite the guitar so it wasn't all bad. The neck was super slim and I thought it was OK until I got a job and a proper guitar which showed it for what it really was. I think I might have put in a bridge post too but it was over 35 years ago and my thingy isn't whatsit.
Me in 1983/84 heavily under the Duran Duran influence and no doubt some mushrooms or other hallucinogen, John Taylor Hair,and frilly shirt were far more important than the vox bass I was playing at the time. It was all about the Girls
https://www.facebook.com/rendallsrestorations?fref=ts
Here's some of me from the 90s captured from video. Top 2 are with a Yamaha RGZ621 which I've mentioned here before, bottom left MIJ 62RI strat (although you'd be hard pressed to tell) and bottom right with a Gordon Smith a few years later with less hair (1996 at a guess)
http://i1108.photobucket.com/albums/h411/tramp5/Old-Guitar-Video-Montage.jpg
@geepers0677 - thought these might amuse you
