EMG 89/SA/SA wiring help
BorkBork Frets: 259
edited November 2020 in Making & Modding
I want to wire my HSS strat so I can select bridge and neck pickups in the middle position of the 5 way selector.
Is this possible?  I have a feeling it may not but google is not my friend, nor Yahoo for that matter.
If it is,  would the mod be a simple rewire of the pickup selector like on a passive strat?
[This space for rent]
  • exocetexocet Frets: 1988
    You need a Superswitch to do this. Here’s an example used on Nashville Style Telecasters (3 pickups). https://www.pinterest.co.uk/pin/557883472568843490/
  • ICBMICBM Frets: 73077
    Yes, unfortunately you need a complicated switch to do this apparently simple thing - it’s because the standard 5-way is actually just a 3-way with extra notches.
    There’s a version of the Schaller Megaswitch which does it too, which is simpler - the E model. I’m not a huge fan of the feel of them and I’ve seen a couple of reliability problems with them, but they’re not bad.
    The switching with EMGs is always the same as for passive pickups.
  • FelineGuitarsFelineGuitars Frets: 11767
    Or just add a mini toggle to give you the option of 2 more sounds to the 5 way
  • BorkBork Frets: 259
    Thanks chaps
    I'm reluctant to drill a hole in the pickguard, in what is already a neat layout that relies on push pull pots to split the 89.  I guess I'll have to nose about for the Schaller Superswitch E (thanks @ICBM ;;).
    Also - while I have your attention, the single coil mode of the 89 is a lot quieter than the middle and neck SA's .  I was going to reduce the heights of the SA's to match the output of the 89 in single coil mode but the 89 would still jump significantly in volume when HB mode was switched in.  Specs of the output voltage for both pickups say 1v (89 in SC mode) so perhaps this difference is not intensional on the part of EMG.
    89 spec
    SA spec
    Am I missing something?
    The other way to do it is to replace one of the Tone pots with a Blend pot. Basically it’s a pot with a break in the track so that you can “break the circuit” when the pot is at the end of its travel. So you end up with a Master Volume, Master Tone and a Blend that fades in the Neck p/u when switch is set to Bridge and visa versa. I have one of my Strats set up this way.
    Unfortunately the spare tone is already a tbx boost.  There's not much flexibility beyond the pick selector.
    Not sure - I've noticed this with a three-SA set as well. The bridge is much quieter than the other two, and even than the bridge+middle - on a passive guitar the loading of the pickups on each other reduces the volume of the parallel positions, but this doesn't happen with the buffered EMGs, so the bridge then seems unusually quiet compared to all four other positions.
    You could swap the wiring of the neck and middle if position 2 is not so important to you
    Position 2 is important for practicing those Alan Murphy lines :-)   His signature sound was 'position 2'
    I'd like to avoid taking the guitar apart and checking the wiring.  It's a 12 year old prewired pickguard as well with the EMG proprietary socket system so I would be very surprised to find any mistakes.  The awkward thing is that the coil switching method for the 89 isn't clear, the website says the switching is 'electronic'.   It might as well be voodoo for all it matters!
    I suppose an email to EMG  technical support may be the only option.
  • FunkfingersFunkfingers Frets: 14787
    No. All of the EMG dual mode humbuckers do that, sir.
    In theory, it ought to be possible to add a resistor via the shunts on the push-pull mode switch for the -89. I have no idea what values would bring the -89 output down to -SA level.
    My own solution to this dilemma was to use an EMG-HA in the bridge position and dial in an -SPC mid booster to get humbuckeresque sounds (and power). Very Gilmourish. ;)
    The superswitch and Seven Sound suggestions depend on permanently soldered connections at the selector switch end. Solderless™ wiring harnesses will require some modification.
    Or swap bridge and middle. That would give you neck, neck+bridge, bridge, middle+bridge, middle in that order.
