I’ve also installed hangers on block walls in the past and I used fisher duo power plugs. If they’re lightweight blocks I’d recommend not using hammer drill setting.. just take your time and work your way up through drill bit sizes. If they’re heavyweight blocks you can be a bit more aggressive.
I’ve also hung them on stud walls too but always drilled directly into a stud rather than trusting any plasterboard fittings.
https://youtube.com/@alexfarranguitar
https://instagram.com/alexfarranguitar
I had one hole, not into the masonry. It went into the lime mortar and the rawplug was loose. I removed the rawplug, put some adhesive in there, put plug back in and no worries.
I know what you mean. I thought the the raw plugs were a bit flimsy, but how heavy are guitars?........ it’s not like we are fixing the Wife to the wall. I have to work a Saturday to buy her chocolates
