Sell me your uncovered bridge humbucker
edited November 2020 in Parts £
Hello,
As title! Don't wanna spend more than £30 ideally, but it'd need to be an upgrade on my Roswell. So I'm thinking Tonerider, Iron gear?
  • Spacing?
  • Spacing?
    For LP shape.
  • FunkfingersFunkfingers Frets: 14575
    That’ll be approximately 50mm UNLESS the LP is an Axcess model with a licensed Floyd Rose double locking vibrato system.
  • I’ve just discovered that the uncovered bridge pickup in my Cole Clark Mistress is 50mm when it should be 52, and I’m looking to replace it anyway so that might suit? It’s four conductor and fairly hot. Can take pics and do measurements tomorrow if you like?
  • I had no idea there were different types aside from normal and F Spaced?
  • Normal is 50mm, f-spaced is 52mm.
  • Ah, I knew there were 2, never seen them written out as measurements before
  • Some f spaced are 52 and some are 53
    My 1986 Ibanez RG410 combines a mk1 Edge double locking vibrato with 50mm-spacing humbucker, skewed off at the “Edward” angle.
    None of the polepieces aligns very well with any of the strings. The two E strings only pass over one polepiece of the humbucker. Looks odd but still seems to work.
  • ColsCols Frets: 7112
    I have an uncovered black bridge humbucker from an Epiphone; yours for a tenner.
    Thanks but I'm looking for something that's more of an upgrade on my existing. Sorry, I should have said originally.
