There is a school of thought that the neck plays a more important role than the body in terms of the sound of the instrument,
Surely the new and used market is swamped with Strat shaped objects? There must be a guitar that would fit any player’s exact requirements out there already - and which carries none of the ‘will it be any good?’ risk inherent in an instrument that you can’t play until it’s finished.
Personally I like the US Standard necks, so wouldn't suggest that needs "upgrading", other than that I personally prefer a nitro finish if possible.
As long as it's put together well it'll perform well imo, the neck is the most important bit for me
I should point out I'm not building one off necks anymore, they take me way too long so only full builds now, I string every neck up and tweak it whilst strung up, this takes time but the results speak for themselves imo
(formerly customkits)
If you are buying bits, then paying someone else to put them together, you could probably save money by just buying a guitar and upgrading a couple of bits.
And of course getting exactly the spec you want, though you obviously need to know what spec you want to make that a positive.
A £150 squier strat sounds as much like a strat as a £5,000 custom shop strat. One just feels a bit better and has more refinements. Tonally, a pickup upgrade would get you 99 percent of the way to the same sound in most playing scenarios.
Not saying the more expensive one isn't worth it, that's a very personal decision... But it's worth thinking about fettling a second hang guitar if you just want a good guitar.
That said, I have a JM and a P-bass that were scratch-built from parts and both worked fantastically from day 1.
Because:
I like noiseless pickups
SS frets
Flatter radii
Very lightweight
Contoured heels
Til now I could pretty much not get that in stock configuration.
The new Fender Ultra Range ticks a number of those boxes though - tempted...
