Feedback
It's actually a stock rotary - guitar is on the way and I've never used the rotary setup before, so will most likely play around with it for a little while before making any alterations. But I instinctively have the same reservation as you re: reference point so started thinking about the McCarty wiring alternative, in case I decide I can live without the various coil permutations of the rotary.
I could just about see the point if it had more sounds than you can get with simple switching, or some really different ones, but just to get five sounds it seems like a backward design step. You get six with a toggle and just one pull-switch...
Anyway - I might fall in love with the rotary so will give it a fair shake!
But give it a go and see what you prefer.
What I didn't like was not being able to tell what position I was in during a gig.
Feedback
Not being able to just hit the switch with the side of your hand in between beats, you have to grasp the knob.
Not being able to quickly change from one position to any other except one of the end positions without having to count the clicks, or go all the way to the end and then back one.
The loud-quiet-loud-quiet-loud arrangement, with the resulting wrong output level if you click it one too many or too few (much worse than just getting the wrong type of sound).
The only real disadvantage of the toggle and pull-switch is that some changes need two hand movements, but I never found that a problem - I could even do that quicker than having to turn the rotary.
@ICBM when you've done the mod, how did you go about enlarging the hole? Tapered reamer followed by drill bit?
My solution was the Freeway 3X3-03 six-way toggle selector. It will take some head scratching to wire up the pickup permutations you require but the effort will be worth it.
No it doesn't. You just avoid having that awful sound .
It works exactly the same. The only difference from a normal coil split scheme is that the connections must be to ground for one pickup and to hot for the other, which one is which depending on the coils you want to leave on - outer coils requires neck to hot and bridge to ground. (Edit - diagram below is correct.)
Looks like the standard split they're showing is for splitting to the inner coils, so using the treble wiring scheme for the neck (and vice versa) should split to the outers.
I actually quite like the inner coil series for cleans, a nice beefy sound that's a bit treblier than the neck humbucker. But the inner vs outer parallels is pretty much redundant on a 22 - there is a bit of a difference but it's very slight, and I actually prefer the outer split.
Beyond that, using the rotary is OK-ish. It's actually pretty firm to engage so hard to just roll off with the palm. It's pretty much a "grab it" job, which isn't great with a pick. And the fact that you need to rotate it towards the bridge, so to speak, to move towards the neck pickup is throwing me off!
Given all that, I think a McCarty setup is on the cards. I can live without the inner series setting, given the convenience trade-off. Will give it a few more days though.
I agree about the difference between inner and outer coils being fairly useless on a 22 - it’s much more noticeable on a 24 because the inner coils are closer together relative to the outers, so more Strat-like.
You do lose the series inner coils sound, but you also gain the both full humbuckers, which to me is a far better sound - it’s the one I use most.
By the way, it’s much better to do the coil splitting by simply connecting the red wire to hot or ground - if you ‘move’ the connection as shown in that diagram you leave the unused coil ‘floating’, which causes noise.
So basically both reds on the middle tabs of the push-pull, and then for the top tab: ground for the bridge side and toggle hot for the neck side? (leaving bottom row unused?
Edit: my bad would have to be reds on top and ground/hot on middle (otherwise the neck pickup would be disconnected altogether when not split)
For what it's worth, the reason I wired my Dragons the other way round is to do with physical layout in the cavity - with the bridge being switched to hot, I could more easily connect the bridge side of the toggle switch to the push-pull, as I wanted to do it with the DGT-type 'partial split' resistors. The resistors do make a noticeable difference to how good the split sounds are, so well worth considering.
