recording studio help
vizviz Frets: 10700
edited February 2021 in Studio & Recording
HELP!
I need to turn a bedroom into a recording studio. What do I need?
I have:
throat
guitar
keyboard
mics etc
audio interface
PC
audacity
I don't have:
sound damping stuff
sound proofing stuff (to stop other house noise leaking in)
monitors
pop shield
closed-back headphones
better mic & cradle
probably lots of other expensive stuff
Can someone please guide me through what I need to get?
  • This is an informative/funny video:
  • vizviz Frets: 10700
    Great thanks - will watch!
  • octatonicoctatonic Frets: 33804
    viz said:
    HELP!
    I have:
    throat
    guitar
    keyboard
    mics etc
    audio interface
    PC
    audacity
    I don't have:
    sound damping stuff
    monitors
    pop shield
    better mic & cradle
    Sound Damping: GIK Acoustics
    Sound Proofing: Forget it- it isn't possible without building a room within a room + HVAC etc.
    Monitors: Budget?
    Popshield: Amazon.
    Closed Back Headphones: Beyer DT770
    Mic and cable: Rabbit hole- what do you want it for?
  • StuckfastStuckfast Frets: 2417
    Personally I'd say 'forget it' to pop shields. Better just to put the mic somewhere it doesn't pick up air blasts.
  • MusicwolfMusicwolf Frets: 3661
    octatonic said:
    Sound Proofing: Forget it- it isn't possible without building a room pithing a room + HVAC etc.
    Absolutely.  In fact, never use the term ‘proofing’.  You are talking about sound ‘attenuation’ and there will be a number associated with it (in dB).  If you don’t know how much attenuation you need then you are not in a position to start specifying a solution.
    For acoustic treatment (reducing the influence of the room on the monitored sound) then you will get the best results / £ by going down the DIY route (Rockwool broadband absorption).  The problem is that the smaller the room the greater the need for treatment but then there is no space to install it.
  • What are you trying to do? Track demo's, record acousyic or mic'd up instruments? Mix? All of the above? To what level?
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • spark240spark240 Frets: 2085
    Purpose mad sound absorption can be expensive.....make your own if on a budget.
    Mac Mini M1
    Presonus Studio One V5
     https://twitter.com/spark240
    Reddit r/newmusicreview
    I've got some surplus GIK traps that I could sell fairly cheap.
    PM me if interested.
  • dariusdarius Frets: 632
    Have you tried recording with what you’ve got? Then see what you really need.
    You might be surprised what you can do without.
    Thank you chaps - and Octa I’ll give you a call tomoz or wed, thanks! She’s been recording with a certain setup but the recordings sound a bit sort-of home-made.
  • I did this at home in a not particularly nice sounding room:
    https://soundcloud.app.goo.gl/YwwpBgjGYJkFbDiR6
    I got our old keyboard player to record the piano and send it over to me. I tracked the vocals, and added the guitar (at 01:30, in one take - should redo it, really), then did the mix.
    I used an AKG C 414 B-ULS into an SSL+ interface into Logic.
    So, you should be able to fee a good sound at home.
    R.
    No worries.
    They are all boxed up and ready to ship.
