Electric showers, educate me.
  • russpmrusspm Frets: 443
    hassleham said:
    I have an 8.5kW shower and I find it goes far hotter than I need it to but the pressure is rubbish. I've opened it up to clean the filter and sadly it didn't make a difference and there doesn't seem to be a way to adjust the inlet pressure to allow more water through. The water pressure from my taps is insane so I don't really know where the problem is.
    I was reading up on it and found out about a pump that goes before the shower to increase the pressure, so that sounds like what you need.
    It reduces the flow to enable the heating up of the water. The higher the kw rating of the shower the better the flow as it can heat the water quicker.
