Feedback : https://www.thefretboard.co.uk/discussion/58125/
GLWTS..
Completely different spec means no 'going rate for an SJB' even if it's the same model. I have had many SJB Ants and they were all wildly different.
This one is rather lovely though. Whoever buys it will be happy I'm sure.
The Ant had issues, but they were more down to not knowing how the amp was originally designed so once I'd spoken to the original owner back in the 90's, it all became clear . . . The 12AX7's were too high gain and when fitted with lower gain valves, the amp really sang . . After changing out the Caps and fitting a balanced pair of 6v6's and sorting the speaker it just came alive :-)
I often change my mind about selling it . . . Im really keen on the idea of buying Keeley Hydra and running both my amps together . . . that would be heaven . . . But I just need to sell my Pod X3 first :-)
