Seriously, though, what dindude, monquixote and ICBM said.
The correct answer is to spend a few hours swapping around until you've got a sound you're happy with. But I like running an od into distortion.
If you run my distortion into the overdrive, even set to low gain, it sounds horrendous, but I've heard a distortion into a clean boost sounds much better.
