All passive volume pedals suck tone, even with a treble-pass cap (switchable on the EB).
http://www.theboxwoodchessmen.com/
https://www.facebook.com/tingiants/?view_public_for=231700547508938
One .. between guitar and amp.
The other on my board, which has a buffer.
In both cases I noticed a big loss of top end.
At first I thought my cable was to blame until I bypassed the pedal !!!!
Maybe you need an active volume pedal?
Or just to set your amp for a good sound with the pedal in line and not worry about it?
Sucks to be All Those Buffer Guys.
When engaged, it goes from nothing up to whatever boost you want. Seems nifty but prolly expensive.
Edit
https://www.vertexeffects.com/effects/vertex-boost
You're not using active pickups are you?
I use the guitar volume controls to determine the amount of drive I get from the amp and use my volume pedal after the pre-amp, as a master volume control (specifically after the chorus but before the delays in my set up).
