Amplifirebox Mk 2
NelsonPNelsonP Frets: 3400
edited April 2021 in FX
  • duotoneduotone Frets: 987
    AMPS
    At the heart of AMPLIFIRE-BOX MK II is Studio Devil’s patented, world-class amp modeling, with amps that cover nearly all the sonic territory from Jazz to Djent . They are:
    US Clean: Based on the two-speaker combo that set the standard for clean, loud guitar amps spanning a wide variety of styles .
    D Luxe: Based on a medium-powered, American, single 12” workhorse classic known for its snappy and crystalline tones and coveted by country, blues and rock players .
    D Luxe 2: Based on the same amp as D Luxe but featuring a more accurate cathode-biased amp modeling engine for better dynamics, tone, and feel .
    ‘59 B Man: This legend started as a bass amp and is known for its diverse tones and touch-sensitive dynamics .
    Top Boost: Based on a British classic, this “Class A” 2x12 is known best for its chime, jangle and its beautiful, unique voicing whether played clean, dirty or in between .
    Top Boost 2: Based on the same amp as Top Boost but featuring a more accurate cathode-biased amp modeling engine for better dynamics, tone, and feel .
    Plexi: Based on THE British amp that defined rock as we know it .
    Brit 800: Based on the early 80s British 100w head that helped defined metal .
    Hot Brit: An Atomic original model, this amp is inspired by the great British rock amps but has a tighter low end and more gain on tap .
    Recto: Based on the amp that defined much of 90s’ rock/metal . This model has tons of gain and compression on tap . It sounds great with scooped mids and has a powerful bottom end .
    5051: Based on the original signature amp of one of the most influential guitarists of all time, it has become a Metal standard
    Kornfield: Based on a very popular boutique model, this amp puts its own aggressive but responsive and nuanced spin on the Brit sound . It also cleans up well when you turn your guitar volume knob down .
    SLO: Based on an American-made, high-gain head versatile enough to play blues, rock or roaring metal . It features a signature clipping preamp that creates cutting tones .
    Freeman BE/HBE: These are based on the channels of a ridiculously popular boutique “Hot Rodded” Marshall variant that has taken the guitar world by storm.
    Rumble/Rumble Bright: Based on an uber-expensive boutique amp known for note “bloom” and cherished by jazz/blues/fusion players, these “Steely” channels let you get your “D”-style thing on.
    Marc IV Lead/EQ: This distinct, California-made monster is known for aggressive tone and powerful EQ sliders to shape the tone to perfection . We give it to you both ways with that seminal EQ “smile” curve enabled and without.
    Arkhan: Based on an American amp made by a revered guitar builder, the Arkhan’s lead channel was designed with five gain stages before the master volume, delivering full, lush distortion .
    SV Tee: This is a bass amp model based on the legendary 300 watt tube bass amp monster that changed the world in 1969!
    “Power” Amp Models: We provide authentic-sounding power amp sims for tube types; EL34, 6L6 , KT88 and EL84 for use with your favorite preamp pedals . Each has a particular sonic character, so experiment and find out which one works best for you . On Power Amp models, only the Master and Presence knobs are active . The Level knob still controls the overall output .
