This is quite a long run through on the Orca delay. Basically four modes: digital ( which also subdivides into analog or lo fi) , tape ( control over wow and flutter etc), diffuse ( add reverb to the delayed signal) and ambient ( add pitch shifting to the delays). The secondary functions allow you to fine tune the settings.
The ramp switch can be used to put the pedal into momentary mode or ramp up the functions you choose. There are two presets and tap tempo and subdivisions.
Does less than the big box delays but maybe less faff than using say an editor on a tc Flashback. Sounded nice.
