The best alternative would be Dr Thomastik silk and steel, or Newtone Heritage in a very light gauge.
Cheers, I’ve tired them before but wondered if anyone knew of any ‘secret’ high end ones...
Here's some on amazon Black Classical Flamenco Acoustic Nylon Guitar String Tie Alba Guitar Beads Blocks : Amazon.co.uk: Musical Instruments & DJ
Also, as others have said, a knot. No reason not to do this, just looks untidy.
An Alternative Method of Tying Off Strings at the Bridge – Classical Guitars Plus (classical-guitars.plus)
Some people seem to want to stick a little bead under the knot!
Alternate stringing method for classical guitars - KieselGuitarsBBS.com
Hope all helpful. Have fun experimenting.
I thought about those bead blocks too, look like the easiest answer
The current bridge is like one found on a typical steel string guitar - think your average acoustic bridge. It’s a a blooming disgrace that someone put that on a 1840s Martin, and I’m hoping soon to finally have an original pyramid style bridge put on.
Even high tension nylon are nowhere near acoustic or electric guitar string tension.
We (D'Addario) make a couple sets.
https://www.daddario.com/products/guitar/classical-guitar/folk-nylon/
____________________
www.adamironside.com
www.youtube.com/Adji87
Simply put the nylon string through the hole in the ball and tie a knot behind it. You don’t need to loop it round the groove in the edge. I’ve done this whenever I’ve needed to restring an old pin-bridge nylon string guitar.
I could be wrong but I think the original Martin bridge would have been a pin type anyway, even though the guitar would definitely have been made for gut strings - steel wasn’t used until the 20th century, so don’t put them on (even very light ones).
