Adding google search to site?
I was just about to make a post but thought that my question has probably been asked before so decided to search.
I'm sure it's not news but the search doesn't work very well to do this. I get that it's a limitation of the forum software.
Is it possible to add google search somewhere on the site. My understanding is that it's a few lines of code to add a search box and then you can tell it to only index this site.
As an ex software developer I get that it's possibly not that easy to add something external to the site without breaking it. Just wondered if it's been thought of and if it's a possiblility.
Meanwhile I'm off to ask a question that I'm sure has been asked before.
  • RolandRoland Frets: 8714
    edited August 2021
  • rze99rze99 Frets: 2292
    Just use google and name the site explicitly also use the filters for date of content.
    The site search is so bad it is not usable.
  • webrthomsonwebrthomson Frets: 1031
    just preface your query in google with the site like this:
    site:www.thefretboard.co.uk <Search terms here>
    So to find Disaster area in Google you would do:
    site:www.thefretboard.co.uk disaster area
  • I mentioned this a while back in a thread moaning about the search but as nobody said anything I assumed it couldn't be done. I find the Google search thing a complete faff to have to write out the whole web address every time I want to search for something so I just ask my questions without checking if they've been asked before :) that makes me a bad person, I know, but hey ho
    soundcloud.com/thecolourbox-1
  • monquixotemonquixote Frets: 17630
    When people are moaning about the search being unusable I can only assume they haven't worked out how to use it properly.
    Use the advanced search and set the criteria properly.
    I always find what I'm looking for.
  • TTonyTTony Frets: 27598
    edited August 2021
    Maybe some guidance might help people "set the criteria properly" @monquixote - similar to the guidance notes that were prepared for embedding images (etc)?
    I'll freely admit that I've never managed to get it to work effectively.  Rather than have a few hundred/thousand people fiddle about with it individually, wouldn't it be more efficient to post some "how to" guidance?
    [PS]
    Functionality aside, the UI isn't really intuitive, so a bit of a re-design of that would probably help quite a bit too.
    It's unintuitive and the default search options are unhelpful.
    Both a guide and a couple of layout tweaks would doubtless help a great deal.
  • fastonebazfastonebaz Frets: 4106
    Search via mobile doesn't allow sort by date which is most useful.
    Indeed that could do with fixing.
  • JonathangusJonathangus Frets: 4536
    edited August 2021
    If you turn your phone sideways, a 'More Options' button reveals itself.
    EDIT: which doesn't allow sorting, but you can select last week/month/year, etc.
    Trading feedback | How to embed images using Imgur
    As for "when am I ready?"  You'll never be ready.  It works in reverse, you become ready by doing it.  - pmbomb
    @monquixote - if you prep some "how to" notes, I'll happily read through and trial them from an idiot user perspective.
    :+1:
  • digitalscreamdigitalscream Frets: 26620
    It's been on the list for....well, forever.
    The advanced search is actually way more capable than Google for searching this site, because it has access to things like categories and dates. The only thing that doesn't seem to work well (and I don't fully understand why) is the username search in the option - it works perfectly well in the search field using advanced syntax.
    Here are a couple of useful examples...
    Search for all posts by me mentioning the Helix
    Search for all ads for a Helix in the classifieds, most recent first
    Note that to use the advanced syntax (in the first one), "Phrase Match" has to be set to "Extended".
    <space for hire>
  • relic245relic245 Frets: 962
    I feel a bit silly now. I've looked many times for the order by option but somehow been blind to it. There is it.
    Thanks. I'll start to use it more often now.
    To be fair, it's probably the most unintuitive layout I've ever come across. At  some point, I'll get around to properly fixing it.
    <space for hire>
    :+1:
    For something like searching the classifieds I would say:
    1. Go to the advanced search page.
    2. Choose "all" rather than "any" for the phrase match
    3. Select the relevant forum (for example "FX £")
    4. Order by "Most recent"
    Optionally set the "newer than" field
    Thinking about it, "Extended" works exactly the same as "All", but with additional options - which is essentially how Google's search operates. I'm tempted to make it the default for all searches (ie the main search box), and "More Options" then becomes the advanced search page.
    That way, you can use all the operators from extended mode straight away..
    Also, Recent First is plainly the most sensible default.
    <space for hire>
    Would you believe that I never worked out that I needed to enter "@user digitalscream" to find posts by a specific person.
    I'd tried using @digitalscream ; or @user=digitalscream or @user:digitalscream (and various other combinations), but never the simple @user digitalscream.
    That's probably the sort of tip that is needed ...
    That makes perfect sense.
    I think on some sites "relevance" makes sense, but given that people are probably searching the classifieds more than anything else recent first a better default.
  • mrn1989mrn1989 Frets: 240
    edited September 2021
    I get that my thread is in the same vein as this thread however, the google search doesn't narrow down to certain items within specific threads unless somebody knows a trick via iPhone that I'm not aware of??
    Ok, I've tried switching to the Full Site on the safari app which kinda works but not fully.
    If I search for "Xotic sp comp", select the FX classifieds thread and sort by most recent it comes up with these results.
    https://i.imgur.com/HoL9oeP.png
    https://i.imgur.com/9icTGfk.png
    However there is a thread created August 22nd which includes the key words "Xotic sp comp" but doesn't show in the search results, any idea or should I just put up and shut up?.......I expect probably the latter XD
    https://i.imgur.com/c1sC2V1.png
    *EDIT I did also try "Xotic sp compressor" and got the same results
    Fretboard Feedback https://www.thefretboard.co.uk/discussion/58705/  ALSO Over 500+ 100% feedback eBay transactions
  • @mrn1989 - try it now. I made a bit of a boo-boo, and the indexer hasn't been running properly since the changes I made to mitigate a DoS attack a couple of weeks ago.
    <space for hire>
